11 years agoClock Data Recovery Stratix V (time needed)
Good evening, I want to know how much time is needed to lock the Clock Data Recovery (CDR) circuit. I am working on a project in which: 1) the data rate is 10Gbps 2) works with TDMA oper...
11 years agoHi,
As per the device datasheet, minimum time required for the CDR to lock to data after the rx_is_lockedtodata signal goes high is 4us. You may refer to Table 23. Transceiver Specifications for Stratix V GX and GS Devices of the SV device datasheet for further details. I believe the OLT solution provided by Altera might have some custom logic to enable fast locking. You might need to contact Altera on this.
