10 years agoCIC IP Core in Quartus 15.1 for 5CSEBA5U23
I develop project for SOC 5CSEBA5U23I7 in Quartus 15.1. I use CIC IP Core. When I choose in IP Core settings "Number or interfaces" >1 (more than one) in decimation mode, I can't get signals "out_startofpacket" and "out_endofpacket". Can anyone help me with it?
I am getting "out_startofpacket" and "out_endofpacket", but for Cyclone IV. However, the CIC compiler does not generate matlab script for the compensation FIR coefficients. It's not even mentioned in the CIC setup. Regards! NJ - Altera_Forum
--- Quote Start --- Hello, I am getting "out_startofpacket" and "out_endofpacket", but for Cyclone IV. However, the CIC compiler does not generate matlab script for the compensation FIR coefficients. It's not even mentioned in the CIC setup. Regards! NJ --- Quote End --- I got "out_startofpacket" and "out_endofpacket" in SignalTap for Cylone IV too, but for Cylone V I can't get these signals. - Altera_Forum
This is weird... Unfortunately I can not check with Cyclone V, have no appropriate project. BTW could you please check if it creates the MATLAB script <variation_name>_fir_comp_coeff.m in the project directory for you?
--- Quote Start --- This is weird... Unfortunately I can not check with Cyclone V, have no appropriate project. BTW could you please check if it creates the MATLAB script <variation_name>_fir_comp_coeff.m in the project directory for you? --- Quote End --- Yes, it creates fir_comp_coeff.m in the project directory. - Altera_Forum
--- Quote Start --- Yes, it creates fir_comp_coeff.m in the project directory. --- Quote End --- Thanks for information. For me it does not create the script. However signals missing with your design are ok. I wish there was Cyclone 4 1/2 :) Regards!
