rsing108
6 years agocan't program stratix 10 GX with pcie hard ip+ example design
I am getting the following errors while programming the Stratix 10 GX board with the PCIE hard ip+ example design.
quartus_pro 19.4
Error (18950): Device has stopped receiving configuration data ...
SengKok_L_Intel
6 years agoHi,
To better understanding the problem, could you please provide the following info?
- How do you generate the example design? Is this from the IP GUI?
- Did you connect the board to a proper setup, where there is PCIe reference clock coming to the FPGA end point?
Regards -SK
- rsing1086 years ago
Hi @SengKok_L_Intel ,
I generated this example design using Quartus pro GUI. Specifically, I am following the steps present here
