14 years agoCan't download to FPGA hardware
There is a FFT IP core in my design. I can simulate and compile my design in simulink and Quartus II (9.1) successfully. But when I try to download the design from PC to hardware, there are some W...
14 years ago --- Quote Start --- Yes, I faced the same problem.Just you have to be paient and keep trying that is all I can say.Restart everything that is the only solution.You will definately face it later.I face it when I dont turn off my PC for more than 4 days.. Best Luck --- Quote End --- Thank you very much for your reply! It seems that this error has nothing to do with the system design or my operation. And the solution is only to keep trying.:( I found that if it suddenly becomed successful and JTAG could download successfully, it would keep remain successful for a long time. But at the same time, if I tried another project which contained an IP core to download, it counldn't download to FPGA hardware as before...
