15 years agoCannot Compile Design with Triple Speed Ethernet and Quartus Web Edition
Hello. I've got the Cyclone III development board an dI'm trying to get the thernet working. I used the megafunction wizard to add the triple speed ethernet module to my design. However, when ...
15 years agowell i don't think the development kit comes with a TSE license. if you think your company already has a TSE license on a floating server, you will need to go to Tools > License setup and put the port@server_name into the license file field. when Quartus II contacts the license server, it should populate the below window with all of the licenses it found. TSE should show up in the list if you have it. if nothing shows up you may have network issues
