16 years agoCan someone give a hint of what the problem is? (CycloneIV, PCIe, GigE MAC)
I'm trying to implement GigE and PCIe protocol on CycloneIV starter board. I presume that I'm allowed to use one channel of GXB for PCIe and the other for GigEMAC. The fitter gives me these fol...
13 years ago --- Quote Start --- Yep, got both examples working separately, and even got a from scratch project working with GigE built from megawizard. --- Quote End --- Ok, that's a good start. --- Quote Start --- The problem only seems to be trying both at the same time. I do use both refclks as you described. I'm suspicious of some issue related to transceivers sharing a quad block, perhaps I need to do some special reconfig magic to make them work together? Not really sure. Been banging my head on the wall for a while now with this. --- Quote End --- Hmm, I'm not sure either. The transceivers are in the same block, so I think you need to use a common altgx_reconfig, but I'm not sure how that ties into two separate instantiations of transceiver blocks ... I've never had a reason to try. File a Service Request with Altera. I've filed a couple recently and they have responded pretty rapidly. Cheers, Dave
