gena's avatar
gena
5 years ago
Can not stop next concecutive rx_st_sop
Can anyone in intel help to solve my following issue on pcie core?
I’m designing the PCIe add-in card that has intel FPGA, and using PCIe hard-ip core below.
-Cyclone10GX
-X4, gen1.1a
-Endpoint, Avalon-st
I’m debugging memory and register accesses through the pcie core on the card, by using our diagnostic software.
During debugging, I observed the following symptom on TLP data stream form the core.
Symptom:
Usually, there is no issue on rx_st_sop behavior.
However, by increasing TLP traffics, I observed that core has hold rx_st_sop asserted intermittently, even though user-logic does de-assert rx_st_ready.
Now my user-logic cannot handle TLP packet with this symptom.
I’d like to know if this is a normal behavior of the pcie ip core.
and I’d like to know how to sop next consecutive rx_st_sop in this case.
What do think?
  • Rahul_S_Intel1's avatar
    Rahul_S_Intel1
    To confirm you are using PCIe Avalon ST and User logic right
    • gena's avatar
      gena
      Yes, I’m using PCIe Avalon-ST interface and User logic for its control.
        Rahul_S_Intel1
        I gone through the data base from our system of the issue reported from your side , I could not able to see any one have reported the same behaviour by increasing the TLP.
        For further issue debugging ,the issue have to replicate inhouse , that limitation is there
