10 years agocan I use 10G PHY IP core without Transceiver Reconfiguration controller
Dear Sir, I am using 10G PHY hard ipcore. I am not changing the reconfiguration of 10G PHY IP core dynamically. So can I use 10G hard ip core without transceiver reconfiguration controller in Stra...
10 years agoTransceiver reconfiguration controller IP does calibration as well. So you should connect a transceiver reconfiguration contorller to your Straitx V PHY IP cores. Otherwise, your PLLs/buffers won't work.
For Arria 10, a reconfiguration controller is in PHY IP core. You don't need separated IP cores. One important note is that Reconfig_clk_clock of Straitx V transceiver reconfiguration controller and CLKUSR of Arria 10 devices must be in operation when the FPGA turned on. You may refer to Pin Connection Guidelines for your device.
