17 years agoCan I do this in DSP Builder.
I have a turbo decoder written in VHDL and I have performed 'compile' in quartus II. Can I perform a simulation using Simulink, like import my VHDL code to simulink and make use of simulink tools to ...
16 years agoJust in case you are still seeking a solution...
DSP Builder HIL may meet your requirement. If your Quartus II project contains a single clock domain, the project can be imported in a HIL block, and you can test the Quartus II project using simulink simulation. Of course, you can use simulink stimuli and scopes in the simulation.
