17 years agoCan I do this in DSP Builder.
I have a turbo decoder written in VHDL and I have performed 'compile' in quartus II. Can I perform a simulation using Simulink, like import my VHDL code to simulink and make use of simulink tools to ...
17 years agothere is an HDL Import block in DSP Builder that you might try. there are limitations on how it can be used which are covered in the User Guide.
i think the Mathworks also has a solution which allows Simulink blocks to be sinks and sources for HDL which is simulated in the background using ModelSim. i haven't tried this but it sounds useful.
