15 years agoCalculating speed of DDR2-RAM using DDR2-HPC
Hello, i've got a question about calculating speed of DDR2-RAM using DDR2-HPC from Altera. I'm using CycloneIII-Dev-Board and know, that the maximum theoretical speed of DDR2 is: 167 MHz...
15 years agoLatency is not the same as efficiency.
Your commands are pipelined so best case you could get close to 24Gbps but when the DDR2 needs to do a refresh and you're stuck waiting. So the overall speed or efficiency comes down to what read/write ratios and patterns you are using and what addressing patterns you are accessing (sequential or random?). Its a fairly complex calculation and I am not sure Altera can provide an exact answer for your system. I'd perhaps look more at a memory vendor for this sort of information.
