14 years agoburst count
Hi,everybody Will you please explain what's the "Local maximum burst count" meaning in the DDR IP Controller setttings? If I don't use the avalon-bus ,can I use the burst count function? ...
14 years agoDid you remember to run the constraints .tcl script generated for the SDRAM controller as well as add the generated .sdc (timequest) file to your project? If not I would read the controller documentation since it goes through what you need to do step by step.
