14 years agoburst count
Hi,everybody Will you please explain what's the "Local maximum burst count" meaning in the DDR IP Controller setttings? If I don't use the avalon-bus ,can I use the burst count function? ...
14 years agoDear BadOmen,
I think your guess is right, and I understand it through the simulation wave~ Thanks! Then, when I compile my project ,there is a critical warning "Critical Warning: Fitter could not properly route signals from DQ I/Os to DQ capture registers because the DQ capture registers are not placed next to their corresponding DQ I/Os" . Should I take more attention on the DQ assignment? And how can I avoid the warning? Appriciated~~~
