14 years agoburst count
Hi,everybody Will you please explain what's the "Local maximum burst count" meaning in the DDR IP Controller setttings? If I don't use the avalon-bus ,can I use the burst count function? ...
14 years agoHi BadOmen,
I see how the local_ready signal works,thanks~ But I still fell confused about using the Avalon-MM mode of the memory controller outside of SOPC, now I just build my own logic based on the driver example generated automaticlly...
