14 years agoburst count
Hi,everybody Will you please explain what's the "Local maximum burst count" meaning in the DDR IP Controller setttings? If I don't use the avalon-bus ,can I use the burst count function? ...
14 years agoThank you for your answer.
But , if the local_ready is driven low periodly, dose it mean that my logic isn't handled? Then why this happens??? Cause I never used SOPC before, and know little about the Avalon-bus, so I plan to achieve the project using my own logic, and then try the SOPC method. Is that OK?
