14 years agoburst count
Hi,everybody Will you please explain what's the "Local maximum burst count" meaning in the DDR IP Controller setttings? If I don't use the avalon-bus ,can I use the burst count function? ...
14 years agoOK,I just generate the 32bits write data , and the write_req is like this:
but I really don't understand why the simulation local_ready is period signal... code: always @(posedge clk or negedge reset_n) begin if (reset_n == 0) begin write_req <= 1'b0; read_req <= 1'b0; end else if(local_ready) begin if((cycle_cnt >= 10'd1) && (cycle_cnt <= ({5'b0,{5{1'b1}}}))) write_req <= 1'b1; else write_req <= 1'b0; end else if (local_ready) begin if((cycle_cnt > {5'b0,{5{1'b1}}}) && (cycle_cnt <= 10'b1)) read_req <= 1'b1; else read_req <= 1'b0; end end Thank you so much~~~
