16 years agoBug in tri_state_bridge implementation?
Hello everybody, It seems to me than I stumble on a bug in tri_state_bridge in Quartus v9.0: A simple master is connected to 16-bit SRAM through the tri_state_bridge. Only write bursts are...
16 years agoIt's good to hear you solved your problem.
And now I know that the 3-state bridge supports burst-mode. That's the nice thing about this forum. You can learn from it every day. Good luck, Ton
