16 years agoBug in tri_state_bridge implementation?
Hello everybody, It seems to me than I stumble on a bug in tri_state_bridge in Quartus v9.0: A simple master is connected to 16-bit SRAM through the tri_state_bridge. Only write bursts are...
16 years agoHello Ton,
The tri_state_bridge definitely supports burst accesses. I've solved my problem by increasing width (N) of burstcount signal vector from 2 to 3 bits. The supported burst length is 2^(N-1) max. as defined in Avalon bus documentation. regards, fpga-dev
