17 years ago
Bug in Stratix III altlvds?
Hi everybody,
I am trying to set up a lvds receiver with external PLL in a Stratix III device using the megawizard and altlvds function.
Configuring altlvds as receiver + external PLL + DPA works fine, but if a make a analysis and syntheses in Quartus 8.0 SP1, i get the following error:
"Error: The port rx_syncclock (which is the slow clock from PLL running at data rate/DESERIALIZATION_FACTOR) must be connected to use the rx_dpa_locked port when the USE_EXTERNAL_PLL parameter is set to ON"
I read several manuals and figured out, that the rx_syncclock is mandatory if external PLL with DPA is used. But the megawizard is not instantiaing this port!
If I add this port manually, the error message disappears.
Could anyone please confirm the megawizard misbehaviour?
thanks in advance,
lestard
    The behaviour has been apparently updated in Quartus V8.1.
    Thank you for your reply.
    I installed the new version and the bug seems to be removed.
    --- Quote Start ---
    --- Quote End ---
    Running 8.1 and regenerating the macro with Megawizard, fixed the problem for me too.
    Many Thanks.
