EGrub
7 years agoBUG - Fir filter coefficient read mode
Hi all! For writing/reading coefficients I made a wrapper to compute the proper reset before accessing the Avalon slave. Writing seems to work fine but reading has issues Considering the FIR II IP...
EGrub
7 years agoHi Chee Pin!
Yes I have a concern regarding that topic!
In real live there is always a valid address assigned to the input.
If the filter has 256 coefficients there is then no invalid address possible because input width is exactly 8 bit!
So in a real implementation the valid would be always high!
By the way, you should not have negative addresses ;-)
Erich
