CheepinC_altera
6 years agoHi Erich,
Just to update you on my recent finding after running hardware test and simulation. For your information, with my simple test design, I can get the same observation in both hardware and simulation. One thing that I notice is that it seems like we do not need to assert the read signal to retrieve the coefficient value at a specific address. With the coeff_in_areset = 0, as long as your address is a valid value, then the coeff_out_valid = 1 and coeff_out_data will show the coefficient data at that address. When I change to different valid address, the right coefficient data is output. There is one clock cycle latency from address change to the coefficient data available at the out_data. This tallies between simulation and hardware.
Note that I am using Q18.1Pro with A10. Since you are observing differences between hardware and simulation with previous Quartus version, I would like to recommend you to use the latest Q18.1Pro where I observe consistent functional behavior between the simulation and hardware.
Note that it seems like I am unable to attach the screenshot to this post. Will try to email you the screenshot.
Chee Pin
