EGrub
7 years agoBUG - Fir filter coefficient read mode
Hi all! For writing/reading coefficients I made a wrapper to compute the proper reset before accessing the Avalon slave. Writing seems to work fine but reading has issues Considering the FIR II IP...
EGrub
7 years agoHi Chee Pin!
It is not only a mismatch between manual and the implementation. The implementation is for sure wrong! In Quartus 15.1 there is never a valid signal -> so a Avalon Master will never return proper data.
In Quartus 17.1 the valid signal is much to early -> Avalon Master will receive wrong and too much data!
Regarding simulation, I tried to setup a simulation. If I enable the Coefficients interface in Quartus 15.1 it doesn't even compile. With Quartus 17.1 it compiled but it did not work at all -> therefore another bug(s) in simulation as well.
Erich
