12 years agoBIOS does not detect our PCIe card
Hi there, We have a PCIe design on Stratix IV working well when compiled on QII 11.0, but stopped working when compiled from QII 12.1 SP1. Both compile successfully, only that the image generat...
12 years agoHi Hua,
--- Quote Start --- We are indeed using QII 12.1sp1, and the first line of the generated vhd file also indicates it was generated from 12.1: -- megafunction wizard: %IP Compiler for PCI Express v12.1% I also double checked the MegaWizard configurations page by page against the copy that worked (and compiled in 11.0), they are the same. --- Quote End --- Using a file-difference program would be easier :) Did you check the ALTGX_RECONFIG component? Have you read through the document I wrote and posted with this thread: http://www.alteraforum.com/forum/showthread.php?t=35678 I haven't tried these designs with 12.1sp1, but I know they worked with the tools I used when I wrote the document. You could download the code and check it out. --- Quote Start --- Basically we supplied the same source files and configuration files as far as I can tell, to two different compilation processes (11.0 vs 12.1sp1), both compiled successfully but one image fails to be detected by BIOS. Is there anything in the hard core that I can use signaltap to check if the it is in working condition? Like checking the link status or something like that? --- Quote End --- Check the configuration controller completes its reset sequence. The PDF in the thread linked to above has some SignalTap II traces you can try to re-produce. Cheers, Dave
