11 years agoBFM Read from On Chip RAM
I followed D. W. Hawkins ([email protected]) tutorial on JTAG-to-Avalon-MM. There is a task in the tutorial that reads a slave address using the BFM master. The slave is onchip_ram. The problem is...
11 years ago --- Quote Start --- I am very, very sorry to take your time this way. --- Quote End --- No need to apologize. If I'm too busy to read the forum, I simply won't answer :) --- Quote Start --- I was reading my preloaded RAM's HEX in a very very bizarre fashion which led to my confusions. I have spend the whole day debugging it... but I learned a lot about QSys/interconnects/translators/BFMs by probing all of them and how they work, thanks to your insight. --- Quote End --- So I take this to mean that everything is now working correctly? Excellent. I tend to appreciate bugs as an opportunity to learn. If everything "just worked" you'd never gain the insight you obtain by debugging a problem. Of course this appreciation only ever occurs after the bug has been fixed :) Cheers, Dave
