11 years agoBFM Read from On Chip RAM
I followed D. W. Hawkins ([email protected]) tutorial on JTAG-to-Avalon-MM. There is a task in the tutorial that reads a slave address using the BFM master. The slave is onchip_ram. The problem is...
11 years agoThanks a lot Mr. Hawkins for the reply. I went through the other thread before posting here. In the example qsys_vip that you have posted, you have a BFM slave module in QSys. I have a RAM slave module. I see that you are setting slave response latency like this:
`SLAVE.set_response_latency(2, 0); In my case, I know the latency of the RAM ahead of time (you can set it in QSys parameters, can be 1 or 2 clock cycles). I just need to tell the BFM master to wait for it. I went through the "Altera Verification IP Guide" and couldn't find which API sets the master wait time. I found this one: get_response_wait_time()
Returns the wait latency for transaction in the response descriptor that has been
removed from the response queue. Each cycle in a burst has its own wait latency
entry. This RAM transaction is a read transactions with no readdatavalid signal: https://www.alteraforum.com/forum/attachment.php?attachmentid=10160 I assume when you get the value of get_response_wait_time() from slave BFM, you have to send it to the master BFM. What is the API for the master BFM to know about this wait time?
