13 years agoBasic work flow question on Altera DSP Builder
Hello all, OK so far I have created a model in Simulink then after that was working I implemented the same model using Altera DSP Builder Advanced Blockset. I followed the Design Guidelin...
13 years ago --- Quote Start --- Yes I run Quartus from the "Run Quartus" Block in Simulink. Then try to compile in quartus and it never gets past 11% --- Quote End --- At least you are given 11% ! It sounds like tool setup issue. I have never encountered that. I assume you click on the compile button then it runs and sees files. You should trace the messages of compilation then you will spot why it is waiting. Licence issues, clear all your work and restart and that sort of playing with tools else you better destroy your pc and but a new one.
