13 years agoBasic work flow question on Altera DSP Builder
Hello all, OK so far I have created a model in Simulink then after that was working I implemented the same model using Altera DSP Builder Advanced Blockset. I followed the Design Guidelin...
13 years ago --- Quote Start --- Qauartus should be helpful and tell you why. Do you run quartus from its block or have you got a top level your own project then added all required files from dspbuilder to your quartus project. It could simple issue: if you click quartus block in simulink it then opens and loads project then it is up to you to click on run button. --- Quote End --- Yes I run Quartus from the "Run Quartus" Block in Simulink. Then try to compile in quartus and it never gets past 11%
