13 years agoBasic work flow question on Altera DSP Builder
Hello all, OK so far I have created a model in Simulink then after that was working I implemented the same model using Altera DSP Builder Advanced Blockset. I followed the Design Guidelin...
13 years ago --- Quote Start --- Thank you for your reply! OK so I built everything in Simulink using the DSP Builder blocks and everything builds and checks there with no problems. When I go to Quartus and compile it always gets to 11% and then stops and never gets past that. Did I miss a step? Is there something I need to do before compiling my code in Quartus? Thanks again. --- Quote End --- Qauartus should be helpful and tell you why. Do you run quartus from its block or have you got a top level your own project then added all required files from dspbuilder to your quartus project. It could simple issue: if you click quartus block in simulink it then opens and loads project then it is up to you to click on run button.
