13 years agoBasic work flow question on Altera DSP Builder
Hello all, OK so far I have created a model in Simulink then after that was working I implemented the same model using Altera DSP Builder Advanced Blockset. I followed the Design Guidelin...
13 years agoThank you for your reply!
OK so I built everything in Simulink using the DSP Builder blocks and everything builds and checks there with no problems. When I go to Quartus and compile it always gets to 11% and then stops and never gets past that. Did I miss a step? Is there something I need to do before compiling my code in Quartus? Thanks again.
