16 years agoI have always the same problem with the bandpass filter output signal
I changed coef more than 20 times.... some one can help me please to design a good bandpass 50hz filter with the fir compiler sample rate 1000hz cutoff freq1 : ~ 20 hz cutoff freq2 : ~ 60 hz or 70 hz number of coef < 30 data in : unsigned width : 8 bits you can use signed input with 9 bits ( sign ='0')
