17 years agoBand Pass filter output data
Hi everyone, I use FIR compiler v8.1 to generate a band pass filter 50hz Configuration : - Input Data unsigned width : 8 bits - I use a coef file generated by Matlab - coefficients scal...
17 years agoYour output doesn't look right.
your input swings between 0 and 243, yet your output is of +160,000 order with repeated close values.It doesn't look you have done any bit truncations. Go to matlab and type: h = < your above coefficients>; x = <your input vector>; now apply filter: y = filter(h,1,x); you should check your results against this as reference I got an initial y values of +80 followed by +4
