17 years agoBand Pass filter output data
Hi everyone, I use FIR compiler v8.1 to generate a band pass filter 50hz Configuration : - Input Data unsigned width : 8 bits - I use a coef file generated by Matlab - coefficients scal...
17 years agoYour coefficients are signed but your input is declared unsigned. I believe this will cause trouble. You can declare your input as signed adding the sign bit = '0' always and see.
