8 years agoBad impact of the alt_fifo on board
I have an altrea stratix V on board. I decided to screw the megafunction FIFO with the asynchronous input / output to the project. After that, the marvell (lan 1000base-T) chip stopped on th...
8 years agoThe problem is solved.
I removed all the outputs in the main module that are not connected and were used only for Modelsim during debugging and it all worked.
