12 years agoAvalon Streaming to UDP Offload example
I've been working through my troubles with the UDP offload example and have successfully implemented this as described in the Wiki. I am now pushing into my next portion of the project, injecting my ...
12 years agoFigured it out.. interestingly enough, the UDP Payload inserter and PRBS Generator are not true avalon streaming interfaces. They make use of the format, but pin the Data Valid signals as soon as you enable the "go bit" via the Nios interface.
A little mucking around there to support the true flow control designed into the interface and everything seems to be moving through again. If anyone is interested I can post my modifications.
