16 years agoAvalon Streaming Interface with FIR
I have the following outputs from an FIR
I’ve got a question relating to the FIR compiler 9.1. The picture shows Source_Valid Source_SOP Source_EOP Source_Channel Source_Ready is pulled high Sweep This is a 2 channel parallel implementation Sweep2 This is a 2 channel serial implementation The problem is that EOP should only be 1 clock cycle.3 Replies
It is only one clock cycle. Both SOP and EOP must be qualified with VALID. so real_eop = eop & valid.
Jake - Altera_Forum
Ok, thanks,
I was just a little concerned that the output signals I was getting didn't look like examples in the FIR compiler manual. - Altera_Forum
do u know where can i get sources which help me in understand the avalon streaming source for design digital filter to implement into FPGA cyclone2?
tq ya
