Avalon ST Multiplexer -> is it possible to concatenate?
The Avalon-ST Multiplexer doesn't have the Packet User Signal, only Start of Packet and End Of Packet.
Again, as for the picture below,
how will the inputs in0 through in19 be scheduled on the OUT output?
The in0 .. in19 are packet based 16bits width inputs (with start-of-frame and end-of-frame signals).
How should I configure the MUX0 and MUX1 so that on the OUT port will be observed packets in0, in1, ... in19 in this certain order (in0, in1, ..., in19)?
Thanks!
Thanks sstrell for helping to answer on behave.
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
Else I would like to have your permission to close this forum ticket
Wincent_Intel
p/s: If any answer from the community or Intel Support is helpful, please feel free to give the best answer or rate 9/10 survey.
- amildm2 years ago
Contributor
The proposed solution is under test, will update the thread with the results
