15 years agoAvalon Slave Byte Enable Interface
Most Altera IPs come with byte enable interface so that if they were used as Avalon MM slaves, they can respond properly according to the asserted byte enable signal. However, I would like to make my own custom accelerator which can take in the byte enable signal asserted by an Avalon MM Master. How is it possible to do this? Thanks!No RepliesBe the first to reply
