Avalon-MM to PCIe address translation table settings
- 2 years ago
Hi BobSD,
From what you provided compared with the user guide. It is seen to be correct.
But I cannot 100 % confirm that as it is your custom design.
As you are using a single MSGDMA.
What alternative you can do to double confirm is to refer to the design example provided in the previous post.
Set the parameter accordingly and monitor if you are able to get the desired output/result.
Let me know if there is any other things I can help you.
Regards,Wincent_Intel
Just one mSGDMA in the design. As I said in my original post, "We walked through how to set up the address translation registers very carefully ...". All I'm asking you to do is check our work as described in the original post above and tell me if we did it correctly or not.
Bob
Hi BobSD,
Wincent_Intel
- BobSD2 years ago
That’s all I needed, @Wincent_Altera. Thank you for the help!
Bob
