10 years agoAvalon-MM slave burst problem?
I set up a simulation to test the Altera mSGDMA core (two instances, one MM -> ST and the other ST -> MM, looped through an Avalon-ST FIFO on the ST side) and used BFMs on all of the mSGDMA MM interf...
10 years ago --- Quote Start --- Shout out to Dave Hawkins for his extremely helpful tutorial and reference design for using the BFMs --- Quote End --- Thanks! Beware that I got the BFMs working "well enough" for my application. It is quite possible that I did not turn on some feature that your design would rely on. I'd recommend filing a service request with Altera and send them your testbench. Maybe you'll get lucky and someone will be able to take a look. Cheers, Dave
