14 years agoAVALON-MM Master Template on DE2
I'm attempting to use the Avalon-MM Master Templates located at: (altera.com/support/examples/nios2/exm-avalon-mm.html) in order to control some external SDRAM on the Terasic DE2 Development board an...
12 years agoI have same issue at here, my setup is: avalon read master talk with a onchip memory2_0. The simulation shows below:
parameter DATAWIDTH = 16, parameter BYTEENABLEWIDTH = 2, parameter FIFODEPTH = 32. It looks the signal fifo_used in a unknown state somehow and cause too_many_pending_reads as well (assign too_many_pending_reads = ((fifo_used + reads_pending) >= (FIFODEPTH - 4))). Thanks,
