14 years agoAVALON-MM Master Template on DE2
I'm attempting to use the Avalon-MM Master Templates located at: (altera.com/support/examples/nios2/exm-avalon-mm.html) in order to control some external SDRAM on the Terasic DE2 Development board an...
12 years agoIt would be much easier to use the read master from the modular SGDMA or the Qsys tutorial design than trying to fix the read master template. In the future the Qsys tutorial masters will most likely replace the existing Avalon-MM master templates.
