14 years agoAVALON-MM Master Template on DE2
I'm attempting to use the Avalon-MM Master Templates located at: (altera.com/support/examples/nios2/exm-avalon-mm.html) in order to control some external SDRAM on the Terasic DE2 Development board an...
14 years agoWell I'm not sure why but I got it to work by increasing the size of the FIFO depth in the master template settings from 4 to 32. It was constantly stuck in a state of "too_many_pending_reads" for some reason.
Thanks for the help and the tips BadOmen. Edit: The problem stems from this line in the latency_aware_read_master file: assign too_many_pending_reads = (fifo_used + reads_pending) >= (FIFODEPTH - 4); If you choose FIFODEPTH as the lowest option (4) and if there are no reads pending and the fifo_used is zero (no words in the FIFO) you still get too_many_pending_reads as high and this prevents it from beginning any more reads at all... even though there never was one to begin with.
