14 years agoAVALON-MM Master Template on DE2
I'm attempting to use the Avalon-MM Master Templates located at: (altera.com/support/examples/nios2/exm-avalon-mm.html) in order to control some external SDRAM on the Terasic DE2 Development board an...
14 years agoThe read master has 16 bit data width and I set the address to 0 just to make sure it's not in the middle of a word.
The problem I see is that it never completes a read. I issue the command and it never replies with "data in the fifo" or "control done".
