11 years agoAvalon MM master read/write template problem
Device: DE0-Nano Cyclone IV-E EP4CE22F17 I'm still new in this stuff and I tried using the SDRAM component of the device using the Avalon MM master read/write. During my initial testing, I was a...
11 years agoDaixiwen, Yeah I was using the same frequency but I was able to visualize the clock signal using nyquist rate (2 times the Fs) so I added a 100Mhz Clock signal so that I can view my sdram clock. Thanks for locked ouput, didn't know the purpose of it until now.
I'm still currently working on the address increment but no luck so far. What I just did for the sake of testing is adding an increment to the address which is signal dependent
