16 years agoAvalon MM Interface
Hi, I'm using a Nios2 processor as an avalon memory mapped master. The Nios2 is connected to a avalon mm slave, which is the controller for a sram. Now I can read and write from Nios2 to the s...
16 years agoOK. Now it's working. It was a problem with the reset of the ip (it was reseted after toggling the reading).
Thank you all for your help. Mark
