16 years agoAvalon MM Interface
Hi, I'm using a Nios2 processor as an avalon memory mapped master. The Nios2 is connected to a avalon mm slave, which is the controller for a sram. Now I can read and write from Nios2 to the s...
16 years agosorry i am not a VHDL guy, only verilog HDL.
but did you look at the master templates ? normaly you setup the addressline, the byteenables, and then assert ther read signal and wait until waitrequest is release (=0). did you monitor via signaltap the slave you want to read from ?
