16 years agoAvalon MM Interface
Hi, I'm using a Nios2 processor as an avalon memory mapped master. The Nios2 is connected to a avalon mm slave, which is the controller for a sram. Now I can read and write from Nios2 to the s...
16 years agoThis is what I do in the vhdl-code above. Reading from 0x0c000000 (SRAM Range: 0x0c000000-0x0c7fffff = 8MB) doesn't run. The waitrequest signal stays high.
