16 years agoAvalon MM Interface
Hi, I'm using a Nios2 processor as an avalon memory mapped master. The Nios2 is connected to a avalon mm slave, which is the controller for a sram. Now I can read and write from Nios2 to the s...
16 years agoIs your address indeed in the SRAM space? You must be careful about one thing: as you read 32-bit values, you must divide by 4 the address that you can see in SOPC builder.
