16 years agoAvalon MM Interface
Hi, I'm using a Nios2 processor as an avalon memory mapped master. The Nios2 is connected to a avalon mm slave, which is the controller for a sram. Now I can read and write from Nios2 to the s...
16 years agoI edited a new component with a Avalon MM Master interface (adress[31..0],waitrequest, data[31..0], read_from_bus, arbiterlock, byteenable signals).
I set all byteenable-bits to 1111 in order to read a 32 bit word, then set the adress of the sram and the read_from_bus signal. After the next clock cycle the waitrequest signal went high but never returns low, which should indicate, that readdata is valid. What went wrong? Here some code:
-- CorrDataReader.vhd
-- This file was auto-generated as a prototype implementation of a module
-- created in component editor. It ties off all outputs to ground and
-- ignores all inputs. It needs to be edited to make it do something
-- useful.
-- This file will not be automatically regenerated. You should check it in
-- to your version control system if you want to keep it.
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity CorrDataReader is
port (
address : out std_logic_vector(31 downto 0); -- avalon_master.address
waitrequest : in std_logic := '0'; -- .waitrequest
data_mm : in std_logic_vector(31 downto 0) := (others => '0'); -- .readdata
read_from_bus : out std_logic; -- .read
byteenable : out std_logic_vector(3 downto 0); -- .byteenable
arbiterlock : out std_logic; -- .arbiterlock
clk : in std_logic := '0'; -- clock.clk
data_out : out std_logic_vector(31 downto 0); -- conduit_end.export
datavalid : out std_logic; -- .export
onlyglass_clock : in std_logic := '0'; -- .export
onlyglass_vsync : in std_logic := '0'; -- .export
arbiterlock_in : in std_logic := '0' -- .export
end entity CorrDataReader;
architecture rtl of CorrDataReader is
type State_t is (READMEM, IDLE);
signal state : State_t := IDLE;
begin
byteenable <= "1111";
datavalid <= '0';
arbiterlock <= arbiterlock_in;
process(clk, onlyglass_vsync)
begin
if onlyglass_vsync = '1' then
state <= IDLE;
read_from_bus <= '0';
elsif rising_edge(clk) then
if onlyglass_clock = '1' then -- triggers read
address <= x"0c000000"; -- sram adress
read_from_bus <= '1';
state <= READMEM;
end if;
if state = READMEM and waitrequest = '0' then
--data available on readdata_in
data_out<=data_mm;
state <= IDLE;
end if;
end if;
end process;
-- TODO: Auto-generated HDL template
-- ADDRESSUPDATE: PROCESS(onlyglass_clock)
---BEGIN
--IF onlyglass_vsync = '1' THEN -- RESET: signale initialisieren
--nextaddress <= x"0c000000"; -- Startadresse SRAM
-- ELSIF onlyglass_clock'event AND onlyglass_clock='0' THEN
-- nextaddress<=nextaddress+0; -- immer 32 Bit = 4 Byte auslesen
-- END IF; -- j
-- address <= std_logic_vector(nextaddress); -- muss unsigned sein
--END PROCESS;
end architecture rtl; -- of CorrDataReader
