17 years agoAVALON_MM interface of TSE
Hello guys, In my system ,I want to use TSE without Niosii.I have use it within NiosII and it works very well.I read or wrote the AVALON_MM interface in TSE module to config the inner registers,bu...
15 years agoHi,
The problem is again solved but this time I don't know how :(.. While looking at the provided testbench, I noticed that they used 8'h02 address for command config register, I changed the register address to 8'h02 and got everything as expected, read back is OK and also eth_mode signal is also high. But as written on TSE userguide, in chapter 4, table 4-9, command_config register address is 8'h08 but I get the correct response by using 8'h02 as done in provided testbench...may be I am doing some silly mistake but I am not able to get it, anybody have the explanation... thanks sawaak
